sdcontreras
5 years agoNew Contributor
I have been using the CBK752 for about a week. AMA.
Generally the signal is stronger than the panoramic and you can put the satellite closer to your garage to hopefully improve the signal. If you can run an Ethernet to your garage or use a power line Ethernet adapter, you can install the satellite in your garage for basically full speed connectivity.
