Clark10's avatar
Clark10
8 years ago
Not getting speed I'm paying for, and daily connection drops.
I've had the Cox 150mbps plan for over a year and have only been getting anywhere between 40-60 on average, I once saw it at 80, but never any higher. And lately I've been having frequent connections drops, usually once a day if not more.
I understand that I won't likely hit 150, but 40-60 on average? I'd like to understand why. And I can't believe I've been paying so much for far less than half of my speed for so long.
SB6183 modem, docsis 3.0. I've pasted my modem signals, as well as errors from my event log below.
Procedure Status Comment
Acquire Downstream Channel   Locked
Boot State OK Operational
Configuration File OK
Security Enabled BPI+
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Corrected Uncorrectables
1 Locked QAM256 30 957000000 Hz 2.0 dBmV 39.0 dB 22 0
2 Locked QAM256 9 831000000 Hz 3.9 dBmV 39.6 dB 190 0
3 Locked QAM256 10 837000000 Hz 3.9 dBmV 39.6 dB 209 0
4 Locked QAM256 11 843000000 Hz 4.2 dBmV 39.3 dB 212 0
5 Locked QAM256 12 849000000 Hz 4.4 dBmV 39.7 dB 165 0
6 Locked QAM256 13 855000000 Hz 4.4 dBmV 39.7 dB 161 0
7 Locked QAM256 14 861000000 Hz 4.4 dBmV 39.4 dB 140 0
8 Locked QAM256 15 867000000 Hz 4.2 dBmV 39.4 dB 146 0
9 Locked QAM256 16 873000000 Hz 4.2 dBmV 39.6 dB 90 0
10 Locked QAM256 25 927000000 Hz 2.9 dBmV 39.3 dB 44 0
11 Locked QAM256 26 933000000 Hz 2.8 dBmV 39.3 dB 68 0
12 Locked QAM256 27 939000000 Hz 2.8 dBmV 39.3 dB 46 0
13 Locked QAM256 28 945000000 Hz 2.6 dBmV 39.2 dB 34 0
14 Locked QAM256 29 951000000 Hz 2.3 dBmV 39.1 dB 20 0
15 Locked QAM256 31 963000000 Hz 1.3 dBmV 38.7 dB 29 0
16 Locked QAM256 32 969000000 Hz 1.0 dBmV 38.6 dB 8 0
Upstream Bonded Channels
1 Locked ATDMA 4 5120 Ksym/sec 36300000 Hz 34.7 dBmV
2 Locked ATDMA 1 2560 Ksym/sec 18400000 Hz 34.8 dBmV
3 Locked ATDMA 2 5120 Ksym/sec 23300000 Hz 34.8 dBmV
4 Locked ATDMA 3 5120 Ksym/sec 29800000 Hz
34.8 dBmV
Mon Jan 15 00:06:44 2018
Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Sat Jan 13 00:06:14 2018 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Sat Jan 13 00:05:39 2018 Warning (5) Unicast DSID PSN startup error
Sat Jan 13 00:05:29 2018 Warning (5) Dynamic Range Window violation
Sat Jan 13 00:05:27 2018 Notice (6) TLV-11 - unrecognized OID;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.0;CM-VER=3.0;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Wed Jan 10 02:13:26 2018 Critical (3) Resetting the cable modem due to docsDevResetNow
Tue Jan 09 21:23:43 2018 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Sun Jan 07 10:25:04 2018 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Mon Dec 25 09:44:52 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Sun Dec 24 08:31:19 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Wed Dec 20 23:55:56 2017 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Mon Dec 18 17:53:17 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Mon Dec 18 17:52:53 2017 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
Sat Dec 16 05:53:38 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:ca:08:72:5e:01;CMTS-MAC=2c:31:24:60:f4:ee;CM-QOS=1.1;CM-VER=3.0;
  • JonathanJ's avatar
    JonathanJ
    @Clark10
    Please email your full address and the primary name of the account holder to cox.help@cox.com so we can take a closer look.
