mike_thorne
7 years agoNew Contributor
if your using firefox then you have a shitload of stuff slowing you down bro load ccleaner i'm not affiliated with them at all just a regular guy then go to plug ins then options and stop all that *** you dont want disable it
Michael-MS
7 years agoNew Contributor III
I'm not even using a browser when this happens. I am losing connection on Streamlabs OBS, Discord, and whatever game I'm playing. This happens on two separate computers. The loss of internet is also visible on any device speed test during the outage time period. It's a problem at the node. I have been doing tech support for a living for 15 years so I'm familiar with all that can go wrong on a PC. Thank you for the advice though.
