- CrystalSFormer ModeratorHello, @Jordanmeares,
You have to stay on top and monitor their activities in this day and age. I have included a link from the Cox.com website that can assist you and also if you Google your question of "Is there a way to monitor web activity for a chile who is connected to the wifi". You will see some results about some software and apps that may also help.
www.cox.com/.../parents-ultimate-guide-parental-controls.html
Crystal S.
Cox Support Forum Moderator - SuperbigwaffContributor
It is possible... but you need a router with "parental control" features. There are many to choose from. First, you need to consider exactly what you want to accomplish. For example,
- Do you want to simply see a report of web addresses the child as accessed?
- Do you want to block specific web addresses?
- Do you want to monitor and limit the amount of time spent using the wifi?
- etc, etc, etc
There are many sites comparing and testing routers w/ parental control features. You can find them easily with a Google search.
I highly recommend this product because I use it myself ...
Depending on the size of your home and your needs, you can get a router for $99.
