5 years agoHonored Contributor III
Do you think the OP was using a toaster oven to configure?
bearone2
5 years agoContributor III
no but i'd almost bet he was using the cox controller!!
You wouldn't make that bet because there are no network settings, selections or options in the cable-box version of Contour.
- bearone25 years agoContributor III
yes there are network settings but not what's required to do what what the op needs.
i posted about needing to switch to wifi to get a needed samsung tv update several months ago.
OP wouldn't have used the Contour remote to configure WiFi for a TV because the cable-box version of Contour doesn't have network settings. From what you've written, you have the Wireless 4K Contour Steam Player. This is an entirely different platform...hence it's name.
