beanbean's avatar
beanbean
Help with port-forwarding
So I need help with port-forwarding on my Panoramic WiFi, and I've been losing my mind...
I've gone to wifi.cox.com and GONE to the network tab AND gone to gateway AND scrolled all the way to the bottom... except there's one problem. Under the more tab, the only tab is Gateway Details and there's no Advanced tab.
I have NO way to portforward and I would really appreciate a reply (please don't tell me to spend 10 bucks on service, a real response with be appreciated)
  • SpartanG087's avatar
    SpartanG087
    The other reply is useless. I found where port forwarding is located and it's really dumb
    Navigate to https://wifi.cox.com/ > Connect > See Network > Advanced Settings > Port Forwarding.
