ChrisL
8 years agoFormer Moderator
@mattselkirk
I see you've been testing your speeds as recently as today and those results appears to be where they should. Are you still experiencing problems or did you make any changes?
-Chris
-Chris
mattselkirk
8 years agoNew Contributor
Hi Chris. Yes, I've been running speed tests and I'm getting nowhere near what I pay for. I'm sitting right next to the router with nothing else connected to the network and I'm getting 51mbps down
I'm definitely still experiencing problems .I just activated my own equipment today and I'm running tests. So far it's not looking too good
Update: just ran the speed test again after rebooting model and hit 35 down
- Becky7 years agoModeratorHi Mattselkirk, so that we can get an idea of your current speeds, please log into cox.com and run the Cox Speed Check Tool several times. Thanks! -Becky, Cox Support Forums Moderator
