Honda600's avatar
Honda600
12 years ago
Broadcast HD digital channels (Clear-QAM)
Found the following response to a question about channels and would like to ask a question related to it:
"Cox does not provide a listing of the Clear QAM Digital channels.  There are only a handful anyway and Cox is constantly changing the channel numbers.  Without an HD STB or Retail CableCARD device all you get are the Local HD channels, available Analog, and a few Clear QAM Digital"
OK, I would like to know why COX does not publish a list of channels that clearly states which ones require cable box or CableCard device and which ones don't?
It is also interesting that to get most cable services requires some type of decryption device which usually have HDMI (or other non-coax) connection to display device (TV or monitor).  So the TVs we buy have television tuning circuits that we don't use (if using the HDMI input).  Comparable computer monitors could be used as display (HDMI-DVI converters are cheap) but on average cost more.  What is wrong with this picture?
  • Domino's avatar
    Domino
    Valued Contributor III
    Honda600: "OK, I would like to know why COX does not publish a list of channels that clearly states which ones require cable box or CableCard device and which ones don't?"
    They do. Go to http://ww2.cox.com/residential/tv/channel-lineup.cox making sure your location is correctly set. The PDF version is easier. Look at the little notations by each channel, and the "footnote" explanation at the bottom of the page. The equipment requirements are listed. Those channels without notation are analog and need no extra equipment.
  • bryaninphx's avatar
    bryaninphx
    Valued Contributor
    OK,  Domino, Let's test your answer based on those notations for the Phoenix, Arizona market, PDF
    http://media.cox.com/support/print_media/tv/cls/arizona/cl_phoenix.pdf
    What is the HD or SD Digital Clear-QAM Channel for the following: (Cox STB/CableCARD Channel in parentheses () )
    (1008) KAET  – PBS HD
    (80) KAET  – PBS Life SD Sub Channel
    (1010) KSAZ – FOX HD
    (1016) WGN HD
    (1017) KPPX — ION HD
    (122) The Pentagon Channel
  • Domino's avatar
    Domino
    (1016) WGN HD
    I didn't say that the ClearQAM channel number was listed (although in my market they are usually the same as the STB channel number. For example, KFMB-DT is 1008 on the STB and 1008 on ClearQAM.) What I said was the little symbols next to the channel denote what, if any, extra equipment was needed. The channels that you listed had either a [triangle] or [Circle], or both, meaning they need additional equipment, which means that they aren't ClearQAM at all. What makes you think that they are ClearQAM?
    bryaninphx
    Valued Contributor
    This was not a trick question, but an exercise showing that Cox does not provide a Channel Listing for the Clear-QAM Channels YES every Channel I listed has a notation of a Triangle, that tells you it is a Clear-QAM, just not where to find it.
    For the Phoenix market all Local HD and Local SD sub-channels are mapped to their OTA channel number.
    Just a few Examples:
    8-1  KAET  – PBS HD
    8-2  KAET  – PBS Life SD Sub Channel
    10-1  KSAZ – FOX HD
    51-1  KPPX — ION HD
    But the Additional available Clear-QAMs are apparently random and channel assignments do change
    79-3  WGN HD
    110-62  The Pentagon Channel
    It would be nice and very easy if Cox would just provide the Channel number listings for Clear-QAM tuners.
    SiliconDust used to provide Channel Listings for the Clear-QAM Channels for every major market, and provider, but they have stopped and now only provide the OTA Channels.
    http://www.silicondust.com/support/channels/
  • Domino's avatar
    Domino
    No, a triangle notation tells you the channel is NOT ClearQAM.
    Nobody has ever stated that Cox provides ClearQAM channel locations.
    bryaninphx
    Valued Contributor
    Cox is really confusing this even more, because EVERY Local HD Channel, in the Phoenix market,  has a Triangle notation. And EVERY channel with a Triangle in the Starter TV Package is available in Clear-QAM in the Phoenix market, also..
    The Trangle Notation states:
    Digital or HD channel included with service level noted; requires rental of digital receiver or CableCARD™, except TV sets with Clear-QAM digital tuner will receive local broadcast channels without equipment rental.
  • Domino's avatar
    Domino
    Yup. Unfortunately, TVs without QAM tuners still exist. Cox is simply saying that TVs without QAM tuners will need additional equipment to view those local broadcast digital or HD channels, while TVs with QAM tuners will not need any additional equipment.
