I tried 4 at local store and they are all the same. Only the 1st digit is bright like our old box was. When you power the boxes on - only part of the b in boot is easy to see. Once the unit comes up when it is between 1 and 9 o'clock you can barely read the numbers from 6 feet away. Yes I have the clock brightness setting at 3. Once 10 o'clock comes around the first 1 digit is easily readable. It has to be at least 3 times as bright.
Yes, I also noticed that a while back when I first got mine...
My box goes to 3 and it's still too dim to read. Last box was at least readable at a distance. This box also displays the first digit brighter than the others.
