My set reminders is not working
My set reminders is not working.
  • Hi @Smich25451
    I know how important it is for you to have your reminders notifications working properly. Have you gone into the settings to make sure that your programs are set up to notify/remind? Also, have you unplugged the Contour box and plugged it back in to see if a reset will fix the issue.
    Ben S.
