Tonto860's avatar
Tonto860
Contour connection
Can the Contour box be connected to a TV that does not have a HDMI connector?
    What you could do in the meantime is...
    1.   go to the following URL
    2.   click the upper-right link (location)
    3.   enter your zip code
    4.   consider your needs (High-Definition...or...High-Definition/DVR)
    5.   click a link of a receiver meeting your needs
    6.   scroll to Back View
    7.   review the connectors
    8.   verify if the connectors are Active
    9.   if a receiver is compatible with your TV, note its make/model on a list
    10. call your Solution Store with your preferred list of receivers
    www.cox.com/.../identifying-your-cox-digital-receiver.html
    • Tonto860's avatar
      Tonto860
      Looks like a Pace unit. Have to check if it has an active coaxial output that I can hook to the TV.
        Oh...you already have the cable box?
        I just checked and the Pace XG2 and Pace XiD have an active coax out.  Pace Xi3 has no coax out.
    • Tonto860's avatar
      Tonto860
      Yes, but I really don't want RCA connectors
