7sudden's avatar
7sudden
12 years ago
Contour iPad App - Home Mode
Just got Contour installed, and now I'm playing with the iPad app. It says that it's in "out of home mode", even though I'm sitting on my living room couch.  -How do I change this?
  • Trikein's avatar
    Trikein
    Contributor III
    First thing I would check is to make sure your on your wifi, and not someone elses. They can sometimes roam automatically. Also, I assume this is a Wifi Ipad and not one with a cellular connection?
    Last, maybe go here on your Ipad. That will tell you what public IP your getting for the internet. If that doesn't match the same one you get when going to the same site on your computer, something is wrong.
  • KipK's avatar
    KipK
    Valued Contributor II
    Good suggestions. Also, one thing we've noted is that the app may sometimes not register the network change when it starts out of home mode and then the iPad is brought onto the correct network, so if you make sure you are on your home network but it still claims you aren't, fully close the app and restart it.
