nort99's avatar
nort99
13 years ago
Westinghouse tv uw40t2bw
I have the black 8820 cox remote, it will not turn on or off theTV. However the volume works and the mute button works, I have tried many different codes with no luck.  I am hoping that some one on here can me out. Westinghouse Model UW40T2BW
Thanks for your help!
  • Domino's avatar
    Domino
    Valued Contributor III
    Follow the instructions at:
    http://ww2.cox.com/residential/centralflorida/support/tv/article.cox?articleId=6f256f70-53e7-11e0-418a-000000000000
  • nort99's avatar
    nort99
    Domino, thanks for the link. I have done all that and more before I posted on this forum.  I have entered all the different codes that I can find. It does work for volume and mute but just will not turn on or off the set and the volume is adjusting on the tv side and not the cable box side, which tell me the code works for part but not all of it.  I am still looking for the answer.
  • Domino's avatar
    Domino
    Try 0885, 0889, 1282, 0000, 0451, 0463, 0623. If they don't work, try 0000, 1100, 0011, 0080, 0111, 0273, 0353, 0810, 0843, 1317.
    If they don't work, and the search method doesn't work, try getting a new TV.
    If
  • ChrisL's avatar
    ChrisL
    It's my understanding that the Westinghouse TVs use random surplus gear from other vendors when manufacturing their sets so the remote codes can vary greatly with those sets.  Domino has some great suggestions although I'm not sure I would replace a TV over the isssue.
  • Domino's avatar
    Domino
    "It's not a TV, it's a Westinghouse."
