I have the
Voice/Internet ModemBrand: ARRISModel: TM3402A
Seems to work BUT with dropped calls and the modem is "HOT"... Meaning, the modem is showing up in "my wi-fi connections" BUT is unsecured. I've looked at the tools and tips for both COX wi-fi and the phone service including the Cox wi-fi app. Nothing is mentioned anywhere that I can see in the forums or online. The phone modem and my Cox Gigablast are split into two indiidual connections from coax wall connection. I only have one wall connection, so my connection options are what they are.
Any insight will be greatly appreciated.
LCW
The 3402 has no WiFi capability. What unsecured WiFi SSID are you seeing?
I am confused. You say you only have one wall connection yet the phone modem and Gigablast(Panoramic?) are separate. Why not use the phone modem for internet and get rid of the splitter? Is it so you can buy your own modem?
As for your issue, the TM3402 doesn't have Wi-Fi, like Darkatt said. See here for specs. My guess is your seeing the hotspot from the Panoramic gateway for your Gigablast service. See here on how to disable.
The My WiFi app is just detecting the telephone modem on its way to your Panoramic. The modem is just connected to your coaxial and about as "hot" as a cable-box.
I have 2 modems as well because the DOCSIS side of the TM3402 went kaput, so I relegated the 3402 to just Voice.
the 3402 has no WiFi capability, you would have to have a WiFi router attached to it.
The app connects to a Cox server. The server connects to your Pano via coax.
