Long story short, I upgraded my internet service from the 300 Mbps service to Giga service. The actual speeds I’m getting are one issue but my real problem is coverage, which is next to nothing once I leave the room where my router was installed (by Cox, originally).
Previously, with my 300 service the coverage was pretty good, and I also utilized a hard wired extender in the basement where my office is located, and my work machines all got a great signal and great speeds.
Now, beyond the room where the router is located the speeds are either (really) 18-90 Mbps or in the basement either no coverage or intermittent connection and speeds which are completely unusable for what I do, let alone any “normal” browsing and streaming.
Cox sold me a WiFi “Pod” device for $120 which is supposed to replace my extender. This thing seemingly does nothing to help, and the only place where I can get it to actually connect and be online is in the living room where the router is. Hence I can see why it does nothing but it won’t go online anywhere else. Before I go ahead and buy more of these infernal pod things, will that help? If I say get two more and put one in our kitchen and another on the basement will they connect in a line and help with coverage?
Or even better, can I buy an extender of some sort and simply plug it into the existing coax cable which is already installed in my basement where my old extender was? I understand the one I had, which was rented from Cox will not work with the Giga service but maybe another kind will? Or are these pods the only solution ?
My house is NOT huge, so these coverage issues are puzzling
thanks!
I'll presume you have a Panoramic combo DOCSIS/router.
If you don't need Pano, I'd purchase your own equipment. At least if the wireless coverage doesn't improve, you could return to using MoCA in the basement.
Yes, I have what should be the newest Cox DOCSIS 3.1 modem/router device.
A buddy who is "in IT" also suggested that I buy a Google Mesh device that I'd attach to my current modem/router but "disable" the Cox unit's WiFi and then use the Google router and pod devices.
I did finally get the Cox Pod to go online yesterday in our kitchen, and directly one floor above my basement office but its doing nearly nothing to provide a usable signal there, which is where I need it the most.
I guess speeds diminish with each subsequent pod, so I see this as a huge issue if I try to add more, as I'm only getting 300-400Mbps from my gigabit service when I'm 10 feet away from the router as it is. Maybe running ethernet cable is the ultimate solution, as I am hearing that I'll never get gigabit speeds over WiFi.
This is all rather ironic and unfortunate I had a perfectly good setup with my (now unavailable) 300Mbps service and the hard-wired extender which provided consistent 300+ Mbps speeds in my office. I feel like I've been sold swamp land by Cox, as in the end I am now getting a far, far reduced TV package and terrible internet coverage for more $$$.
My city only has Cox or AT&T, and on my street the only AT&T is Uverse, which we had and which drove us to Cox in the first place.
