Thanks for all the remote codes. There were some new ones for me... and I was hopeful. But, no joy.
Hi dkretzschmar,
I also have a Samsung TV and the following steps worked when pairing my Contour remote:
https://www.cox.com/residential/support/pairing-or-unpairing-the-contour-remote.html
I hope they will work for you
- dkretzschmar2 years agoNew Contributor
Thanks for the response Michael. That is a good link for remote pairing AND in a perfect world should work. In trying to get the on/off and volume to work on the cox remote, the 5 digit codes usually work, but, in my case, no. Right now I have to use the Samsung remote and the Cox remote... not ideal.
- DannyS2 years agoModerator
dkretzschmar, have you attempted a search without codes. This can be done by holding the A and D buttons on the remote. Until the LED at the top of the remote turns green. At that time press 991, the LED will blink twice. Then begin hitting the channel up button slowly and repeatedly until the TV turns off. Once that occurs, press the OK/Select button and the green LED should blink twice. Then you can try hitting the power button to see if the TV turns back on. If not, you may need to do it again, as if you go to fast. It may not catch the correct code. Hopefully this helps with the programming.
