25_yr_cox_user
2 years agoNew Contributor II
Another list of codes to try
12280 | 10060 | 10812 | 11060 |
12281 | 10178 | 11632 | 10587 |
12284 | 10408 | 10702 | 10217 |
10766 | 10482 | 11454 | 10329 |
10814 | 11597 | 12253 | 10650 |
10032 | 11959 | 11903 | 10030 |
10056 | 10090 | 10427 | 11575 |
13118 | 12278 | 11581 | 11632 |
10702 | 10060 | 11959 | 10766 |
11903 | 11060 | 10587 | 10329 |
10814 | 10650 | 10482 | 10032 |
10030 | 10178 | 10019 | 11575 |
11597 | 10427 | 10408 | 10217 |
10090 | 10056 | 11581 | 10037 |
From How to pair a Comcast Xfinity remote to Samsung TV (knowtechie.com)
- dkretzschmar2 years agoNew Contributor
Thanks for all the remote codes. There were some new ones for me... and I was hopeful. But, no joy.
- MichaelJ2 years agoModerator
Hi dkretzschmar,
I also have a Samsung TV and the following steps worked when pairing my Contour remote:
https://www.cox.com/residential/support/pairing-or-unpairing-the-contour-remote.html
I hope they will work for you
Thanks for the response Michael. That is a good link for remote pairing AND in a perfect world should work. In trying to get the on/off and volume to work on the cox remote, the 5 digit codes usually work, but, in my case, no. Right now I have to use the Samsung remote and the Cox remote... not ideal.
