WiderMouthOpen
6 months agoEsteemed Contributor II
Are you using your TV for audio? If so, does the remote control the audio? What codes have you tried? Last, what model is the TV?
- RBG6 months agoNew Contributor
Audio is fine. Remote works with the TV and a soundbar. I've tried the codes that pop up when I go to the remote settings in the contour menu. The model is VFD32M-0807. Thanks.
- WiderMouthOpen6 months agoEsteemed Contributor II
Did you try 11758?
Yes, that's the default code that shows up when pairing the remote.
