Live TV, no sound bar. Maybe it's a built in feature on my Sharp Smart TV?
Main: 1-800-BE SHARP
1-800-237-4277 (toll-free USA)
Mon-Fri: 8:00 am – 8:00 pm (EST)
Sat-Sun: 10:00 am – 8:00 pm (EST)
www.sharpusa.com/Support.aspx
-Kevin M. Cox Support Forum Moderator
- Pidgy6 years agoNew Contributor
We have this same problem and it's most aggravating. Many years ago, increased commercials volume was outlawed and now it has crept back. This is not a personal television problem. Check it out.
- Becky6 years agoModeratorBe sure to verify that the Audio Output settings within the cable box match the capabilities of your TV and the cables connecting your equipment. For instructions on accessing the audio settings on each specific cable box, please visit www.cox.com/.../audio-settings.html. - Becky, Cox Support Forums Moderator
- Carlosaro6 years agoNew Contributor
Thank you!
The volume, after a few minutes of being on, just increases as if it were giving me a few minutes to settle in. It has nothing to do with commercials or anything. It's slightly annoying but I've learned to deal with it. I don't know the model number of the tv and it's mounted on the wall so a pain to get behind it to see the numbers. I will check the tv settings and as another suggested reset Contour. Although, I believe it's a tv setting the more I think about it. Thank you for your replies.
