I am supposedly getting a Firware Update to my Vecima TAs tomorrow, Friday Nov 10th.
Just me and a few others are going to be the Beta testers.
We'll see. No NDA was mentoned so I'll post here if it happens.
That is great news. Cox is moving at light speed compared with the problems on the Cisco Tuning Adaptors.
Keep us posted if you can.
Thanks.
- bryaninphx2 years agoValued Contributor
Absolutely, I will report back as soon as I get a firmware update.
I never received a notification. But... I just rebooted my Tuning Adapter and TiVo. It works.
Hallelujah, Praise the Lord.I Attemped to upload pictures of the TA Diagnostics, but the uploads fail!!!
Isn't Cox wonderfull??? They're Great at the Communication Business and ITLooks like Firmware Version: jenkins-20231107 (I am assumimng Nov 7, 2023)
eCM Version: BFC5.7.1mp4_20230116
eTR Version: 1.8.0
rootfs Version: jenkins-20231107
eTR OUI: 001848
SN15: H28221117000143EDIT:
Bolt and Roamio Pro work fine.
Elite/XL4 Does not work, I can't access the TA Diagnostics so I don't know if that TA also got the Firmware Update.TA Diagnostics
TA Diagnostics 3- LongTime_TIVO_U2 years agoContributor
Odd that we get excited when Cox manages to sort of fix something. Stepping back, it appears that Cox originally deployed an untested TA update that broke all older TIVOs. You made some serious noise and they responded by scrambling a fix. They mananged to deploy it to 2 of your 3 TAs and it worked. And despite expectations of a coordinated Beta test, they simply threw it over the wall. No notification. No followup. No nothing.
Is this a win? Given the Cox history of stone walling TA problems, yes. Judging them by industry standards, they still have fundamental problems.
Thanks for the feedback. I hope Cox eventually deploys a update to my TA. So far, no changes for me. Tivo Edge working great. Roamio still goes into convulsions when I plug in the TA.
Of course the disaster scenario is when they update my TA, it will fix the Roamio and break the Edge.
