Krc's avatar
Krc
2 years ago
Sound blurrrr
The sound on my tv randomly gets distorted resulting in blurred sound. I am using new cable, contour box with hdmi cable to the tv.
 If I wait a long while it stops. If I turn the power off and then back on or unplug the hdmi cable and put it right back in it fixes the problem.
 This does not happen on another tv using a mini box. I do not want to switch around boxes to the TV’s.
 The box I just turned in had color stream jacks on the back which I had to use to prevent the sound blurrr. The new box has only hdmi. Any ideas how to fix or what causes the random sound blur?
  • CurtB's avatar
    CurtB
    Honored Contributor
    You might need to adjust an audio setting on your TV.
  • Krc's avatar
    Krc
    Thanks i’ll try that. Will have to find OG remote. 😬
  • Krc's avatar
    Krc
    I changed every tv sound function and nothing worked. I thought maybe hdmi cable I had was old so I used new one and still nothing. So I Traded in my contour box for my old box and went back to cable stream instead of hdmi. Working perfect again. I was informed I have a year or year and a half and my box will not work any longer. New tv may be on the horizon.
    • ColleenD's avatar
      ColleenD
      HI, Krc.
      I'm glad to hear you were able to get audio working on this TV with the other box. Were you able to try a different HDMI port on the TV? As of now your current box is still supported, though I'm sorry to hear the Contour box didn't work out for you.
      • Krc's avatar
        Krc
        Hi and Thank you. Yes, I used all the HDMI ports available on the TV. Great idea. I hope cox keeps these OG boxes available for folks like me but I was told they will not.
