vabaylee
6 years agoNew Contributor
The only "code" i see says "XRE-03121". Not that says "error".
KevinM2
6 years agoFormer Moderator
@vabaylee, do you have a splitter in the home? If so, can you bypass that splitter to see if that provides temporary relief? Splitters can lose signal gradually over time or simply fail without warning. From what you're describing, this may be an indication of a signal issue. -Kevin M. Cox Support Forum Moderator
