MariaL
6 years agoModerator
Hi vabaylee,
Is there an error code associated with this message?
Maria
Maria
vabaylee
6 years agoNew Contributor
The only "code" i see says "XRE-03121". Not that says "error".
- KevinM26 years agoFormer Moderator@vabaylee, do you have a splitter in the home? If so, can you bypass that splitter to see if that provides temporary relief? Splitters can lose signal gradually over time or simply fail without warning. From what you're describing, this may be an indication of a signal issue. -Kevin M. Cox Support Forum Moderator
