Trindel's avatar
Trindel
Read a remote code?
How to read a remote code ?  Anyone know how to get read a remote code by putting the remotes end to end and then using the cox remote to acquire the code from the first remote?  The old cox remotes used to do this.  Do the new ones ?
    A moderator would need to confirm, but what you're describing ("reading") would be a Learning remote.  I don't believe Cox remotes are Learning remotes.
