gelder4
8 years agoNew Contributor
The Samsung remote does control the volume. I have a soundbar hooked up to the TV. It is slaved to the TV volume control. I disconnected it from the TV and tried using the internal TV speakers only. The volume control still didn't work with the new remote.
The cable box is connected through the Component jacks.
When doing a code search the search stops when the TV powers off. Is there a way to tell the search to continue after the first hit, so it may possibly find a better match?
