JonathanJ
8 years agoFormer Moderator
@redleg
If the remote turns the TV off and on that means it's program to the TV. Does the Samsung remote adjust the volume? Are you using an HDMI or component cable running from the cable box to the TV? Are you using a sound bar or home theater?
