3 years agoHonored Contributor III
Do you need the TV to turn on the cable box? After you pair the Cox remote to the TV, the remote will turn on the TV.
- Olga3 years agoNew Contributor
I actually have EasyMote (for seniors) paired to the Cox remote. The on button should turn on the TV and cable box together. It only works if the box has been on for a while. Otherwise I get the No signal message.
Are you sure the cable box gets powered off? I thought most of these model remained powered for updates.
They should remain powered on but she has a NEW box that was manufactured in 2013! I'm thinking it is an old product and may be the issue....
