I think the reset you're doing on your TV is only resetting any customized audio/video setting back to factory defaults.
I read something about a "cold reboot" as follows:
- Unplug TV
- Press and Hold power button on TV set for 30 seconds (the TV set)
- Plug TV back in
- rcaron6 years agoNew Contributor II
Ok. I will try that
I did that test and unplugged the Ethernet cable too. Held for 30 seconds, turned tv back on, plugged in Ethernet and it recognized the cable. I’m going to turn it off and on now again.
The Ethernet connection is holding in store mode after the cold reboot. Thank you so much! You’ve made my day!
