JohnC99's avatar
JohnC99
7 years ago
Is there a way with the new Contour to pause and advance frame by frame as the old Contour could do?
  • yak's avatar
    yak
    Contributor III
    I have Contour 1 and have never seen a frame-by-frame option.  only the 2 "slo-speed" options of pausing and then hitting the fast forward button once or twice.   Tell us about the frame by frame: what buttons?
    • CarolLM's avatar
      CarolLM
      Hi there, to use that feature with a Contour 1 box you'll need to press the "pause" button first, then you'll want to press the white left or right buttons with a black triangle on them to achieve the slo-mo frame-by-frame action. Try that and let us know how that works for you. Thanks, Carol
      • yak's avatar
        yak
        Contributor III
        CarolLM,  thanks.  that works perfectly.  do you have any other secrets to share?
  • Hello, we understand what you are asking and you cannot repeatedly press the button to go frame by frame like the old system. The best would be to pause and press fast forward to try and capture the correct frame you are looking to get. -Dan
  • jtaccone's avatar
    jtaccone
    i wish cox or comcast would add that feature as  comcast does own if i am right contour 2 is part of comcast x1 platform
    • LisaH's avatar
      LisaH
      Hi Jtaccone. I will submit your suggestion to the appropriate department. Thank you for the suggestion. - Lisa, Cox Support Forums Moderator
