JonathanJ
4 years agoFormer Moderator
@Peggie
I'm sorry to hear that you've been experiencing intermittent connections. I know how important it is to stay connected, so I can understand your frustration. Have you checked all your connections and made sure they are secure? Also, Are you experiencing this on all cable boxes if more than one?
Cox Moderator
Cox Moderator
- Peggie4 years agoNew Contributor
I have 2 mini boxes. Cables are secure. Having the signal cut out from time to time is not the weird part. It's the skip-and-repeat thing. Originally, I thought it only happened when I watched a particular channel., but I have experienced it on other channels as well. I wondered whether it indicated the box needed a reset, but I don't think that's it. The boxes are reset every night and occasionally, I manually reset them. I may never figure this out because the timing is so random and intermittent.
- DavidA24 years agoFormer ModeratorPeggie,
I understand where you are coming from. Intermittent issues are the hardest to track down and figure out. If you would like for us to take a look at your account specifically, we ask that you email us at Cox.help@cox.com with your service address and a link to this thread.
David
Cox Support Forum Moderator- Peggie3 years agoNew Contributor
About a week ago, I had a technician come to my house and replace the box. The problem has not recurred since. 😊
