CurtB's avatar
CurtB
Honored Contributor
10 months ago
This is how to access Samsung TV settings with a Cox remote
If you have a Samsung Smart TV, you can access your Samsung TV settings with the Contour/Cox TV remote.
Using the Cox remote, press the TV device button, then the CC button.  A Samsung Accessibility Shortcuts  menu will be displayed.  Press right arrow and select Close to return to normal television or press Exit to display Samsung Terms & Policy Setup.   Press left arrow to display Media, then down arrow twice to Settings.  Press right arrow repeatedly to the desired option.  While a settings option is selected, press Exit to return to normal television.  Don't forget to press the CABLE device button to resume normal remote operations.
Cox remote buttons are in bold text.  Samsung settings and menus are in italics.
Note: The organization of Samsung settings may vary for different models.
I discovered this feature by accident.  Has anyone seen it documented anywhere else?
If an individual with a different brand smart TV can use TV and CC to access TV settings, please let us know.
Subject was modified to clarify this post is instructions for how you can access Samsung Smart TV settings with a Contour/Cox TV remote and is not a question about how to do it.
