rkruz's avatar
rkruz
7 years ago
how power off Contour DVR?
I have Contour 2 channel DVR.  Newly installed.   How do I power it down from the remote?  Neither the TV Power or the ALL Power buttons power down the DVR but they do power off the TV.  Any help?
Thanks!
  • Hi Rkruz. The new Contour 2 box is designed differently and has a power save feature so it will in effect turn off when not in use and will turn back on when you select all power on. If you want to turn off the power, you will need to go to settings, device settings and there is a power option to turn off the box. Thanks, Lisa - Cox Support Forums Moderator
