Hiphubby123
2 years agoNew Contributor III
Cox Remote Battery Life
I replaced the batteries in my Cox Cable remote but the onscreen battery life indicator still shows a low percentage of 31%. Isn’t the percentage supposed to update to show 100% after you put new ba...
- 2 years ago
I did check the batteries and they were good. However, I decided to change them again and the next set of batteries worked. The onscreen battery strength indicator now shows 100%. Odd, but the batteries that did not seem to work were Energizer and the ones that did work are Duracell. Maybe the remote prefers Duracell. No, I doubt that has anything to do with it but it was strange. Problem solved.
