I always have seen 100% after changing remote batteries.
I'd check the age of the new batteries first. You could also make sure that the connections are good and that the batteries are installed in the proper orientation. If those check out I'd try different batteries to be sure you don't have some bad ones. If you have a multimeter you can check the voltage of the old and new batteries.
However, if the remote is operating normally it probably doensn't matter.
- 9 months ago
- 3 months ago
- 9 months ago
- 4 months ago
- 4 years ago
