dcwong504
6 years agoNew Contributor
KevinM2,
The Contour box only has two HMDI ports, one HDMI in port and one HMDI out port. I have tried numerous ports on the tv without any success. I also noticed that my tv does not "see" the cable box when I view connected devices on my tv. The tv "sees the sound bar and the Apple tv.
The TV obviously "sees" the cable box because the cable box works...albeit after a hard reset.
This begs the question of your definition of "see." Sony Bravia Link/Sync will not see a cheap cable box. Do you see the cable box if you press the TV Input button on the remote?
