5 years agoHonored Contributor III
Look at the procedures for Code Search at the following link:
https://www.cox.com/residential/support/contour-2-xr5-remote.html
Before you start pairing, however, I'm curious why you're using optical. What's the make model of your LG TV?
IntenseNV
5 years agoNew Contributor II
thank you for the response. I did use the cox link and followed all of the code searches, plus looked on line for more codes. Nothing worked.
The tv is a new LG 2020 model, OLED65CXPUA,
The input was set up the Best Buy installers. From the television the Optical Digital Audio Out is used to the sounder Optical In.
Dave
