CarolLM
7 years agoFormer Moderator
Hi there, our remotes are designed to work with most television sets, but not every single one of them. If your television has the ability to work with our Contour 2 remote TV Input, then you should just be able to press that button in the lower right corner and be able to cycle through the various inputs. If that doesn't work with our remote, then, unfortunately, you'll need to use your TV manufacturer's remote to get to the right input. -Thanks, Carol
