I noticed the new "satellite" Contour boxes can and do use Ethernet to connect to the network, but what about the "main" Contour box? Can it also connect to Ethernet and if so, how do I make it happ...
Hi BillCan. If you have a main or host box, you won't be able to connect to ethernet as the ethernet port isn't active as of yet. - Lisa - Cox Support Forums Moderator
