- LisaHModeratorHi BillCan. If you have a main or host box, you won't be able to connect to ethernet as the ethernet port isn't active as of yet. - Lisa - Cox Support Forums Moderator
- bearone2Contributor III
yes, i connected the actual tv, with it's remote control, in:settings/support, selected auto dhcp, instead of wi-fi, for tv updates & it works for both tv's.
