I am experiencing the exact same issue on my converted G6 box which is the older model Cox box that was converted to Xfinity software. It resets back to 720p every night and requires us to go in and manually switch it back over to 1080p in the boxes device settings every day. Prior to this box we had the Contour XG1 box which did not exhibit this behavior.
Doing some online research, I discovered that Comcast customers were having this exact same issue on their Xfinity boxes a couple years back, but that it was finally corrected with a firmware update from Comcast. I can only assume the Xfinity software being used on the Cox G8 boxes is potentially from the same base software that exhibited this issue at Comcast.
Here is the thread from Comcast.
http://forums.xfinity.com/t5/X1/1080p-setting-keeps-reverting-to-780-when-box-is-turned-back/td-p/2442877
It would be great if the Cox engineers could work with the Comcast folks to get this corrected as it is a pretty major annoyance.
