val1
4 years agoNew Contributor
Same problem. After a system update the box just constantlty reboots.
Pulling out the plug temporarily fixes it until the next system update. Also, "System Refresh" works also until the next system update.
DavidA2
4 years agoFormer Moderator
Hi Val1,
It sounds like the box may be defective. You may want to consider either swapping the box at one of our stores or having a technician set up to swap it.
David
David
