hammerva's avatar
hammerva
Anyone have audio issues after reboot?
Hello.  For some reason my cable box rebooted a couple hours ago.  Since then  I have some shaky audio issues.  Off and on I lose audio to the point I have to change channel to get it back.   Anyone had this before.  I think I might reboot the box again after what I am currently watching
  • JonathanJ's avatar
    JonathanJ
    @Hammerva
    Are you having this issue on all channels and are you using an HDMI cable?
    Cox Moderator
    • hammerva's avatar
      hammerva
      It seemed like the only channel was VICE which I was on when it rebooted.  I was on pause when the reboot happened and maybe that impacted it.  Seems fine this morning but as soon as you pause that channel the sound got messed up
        JonathanJ
        @Hammerva
        Are you referring to Viceland, if so does it happen on 228 and 1228?
        Cox Moderator
