hammerva
5 years agoNew Contributor
It seemed like the only channel was VICE which I was on when it rebooted. I was on pause when the reboot happened and maybe that impacted it. Seems fine this morning but as soon as you pause that channel the sound got messed up
JonathanJ
5 years agoFormer Moderator
@Hammerva
Are you referring to Viceland, if so does it happen on 228 and 1228?
Cox Moderator
Cox Moderator
- hammerva5 years agoNew Contributor
Seems to be both but at the time I was using 1229
- BenS15 years agoFormer ModeratorHi @Hammerva
You may need to toggle the SAP feature or make sure that it is not turned on. Here are instructions on how to turn off the SAP www.cox.com/.../configuring-secondary-audio-programming-for-contour-2.html
Ben S.
