WiderMouthOpen
7 months agoEsteemed Contributor II
Is it just wifi or wired connections too? If only wifi, can you still see your network? Can you connect even if you can't get online? Do you get a IP? Can you ping the router? If wired too, does the light change on the Panoramic gateway?
PS. There is no such thing as a "wifi provider". Wifi is just the tech between your wifi devices and the router. What you mean is "internet" or a internet service provider(ISP).
