Dave9's avatar
Dave9
Contributor III
Dynamic Range Window violation/Commanded Power - cause for concern?
Approximately 10 times per day, I get the following warnings in my cable modem (SB8200) event log: 05/09/2020 07:59 2436694061 5 "Dynamic Range Window violation" 05/09/2020 07:59 ...
  • Dave9's avatar
    4 years ago
    I had a service call today. The tech found that the line from the pole to my house was causing over 10 dB of downstream signal loss, and also found an issue at the pole related to upstream power. He replaced the cable and opened a maintenance ticket for the other issue, and said it should be fixed in a few days. My signals look a lot better and I'm very happy with the quick response from Cox.
