DOCSIS 3.1 not showing up with new SB8200
So.... Everything was working fine on a Arris CM8200A DOCSYS 3.1. All good. Then I had connectivity issues, which started with Cox telling me it was an issue on my end and I should upgrade service (more money). The issue ended up turning into outages over the next two days. Still could not connect. One service no show and then the second service call. The second service call was quite good. Checked and replaces something at the curb, replaced some cables, a bunch of ends, a couple splitters, checked signal all over the place and said it was spot on. When all was said and done, my modem was dead. So I ran to the store and got a SB8200 DOCSIS 3.1. Hooked it up, got it registered. It's working, I have internet, but no DOCSIS 3.1. I did find this article: Not receiving DOCSIS 3.1 | Cox Community, although not much help Been on that stupid Cox App, that keeps dropping chats, for hours a day over a few days. It should not be this hard or take this long. I was told twice (once by CAG) to call the manufacturer because Arris needs to address/configure something and the problem is with the modem. I have called a number of times. Arris states that there is nothing to configure in the modem and it is dependent on the signal from the ISP. If it is getting a signal, then it is working. This makes sense to me. I did reset the modem twice with that little switch. Cox has reset it at their end. Cox tells me they have re-provisioned the modem like it was a new one again. No improvement. I know we have had historic problems with service. On neighbor says he is running an old DOCSIS 2.0 (so he says) and his wife complains that it drops her VPN quite often, and I have another neighbor that is similar to ours, it drops about once or twice a week, usually on the same day. Sometimes cable tv gets pixelated but when reported, apparently that is the signal Cox received. From all this I feel like I know where the problem lies, but Cox keeps pointing me in other directions. Any ideas on how to get my DOCSIS 3.1 working correctly? Please let me know.170Views0likes2CommentsAris SB8200 unable to connect to internet even when all lights are solid and correct MAC and serial number in the Cox system.
I am a new customer and I am trying to use an Aria SB8200 that I had previously used with Xfinity. I factory reset the modem and it boots to completion showing all solid lights, but I am still unable to connect to the internet. I am able to reset my router through the Cox web service. Was on the phone with Tech Support all evening and they weren't able to make it work on their end. Is it the cable modem? It was working perfectly with Xfinity and it is on the list of modems that Cox says will work.565Views0likes0CommentsSB6200 will not connect
Customer since 1995. Bought brand new Arris SB8200. Got it provisioned and support says it connects. On laptop directly connected, I get an IP but cannot ping gateway or connect to anything. Can't ping DNS servers or DHCP server listed. I did not know about the 192.168.100.1 diagnostic webpage of my modem. I guess next time I try this, maybe I will be able to get more information of what the problem is. I guess my home connection might not be completely up-to-par for gigablast? How does one get some tech support to work on this issue? I ended up going back to by Surfboard 6141 and I'm all good. I'm not sure what email replies here go to. But I do not check my Cox email (too much spam). I'll keep trying to check here or email nathan.rutland@gmail.com .. I'd love to get this new modem working. If not, I might ship it back and see if the ATT hangbox is ready to go.Solved1.6KViews0likes3Comments
