Panoramic wifi pod 2.0 will never connect. just flashes white.
So to start off I'm using the PW7 gateway, The brilliant contractor that renovated my apt decided to only put one cable line coming in, in the living room at the front of the house. I ordered a wifi pod 2.0 to help get more signal to the back of the building. I've tried installing it, and three times I got errors saying it could not connect. The app said to unplug the gateway, plug it back in and wait 10 mins, then try again. I did that, 3 times. I called tech support yesterday and the agent really didn't know what she was doing. She was confused why it didn't have a different SSID than the gateway. We both noticed the app was updating about 10-15mins later when I connected a device (echo) to the network. so I figured something was just not working right on the backend I tried again this morning. now it's saying it just can't connect and won't install. I took it one step further and signed into the admin page for the gateway and did a factory reset. Tried to chat with someone in tech support and all they did was cut and past instructions to me. zero help. Does anyone have any ideas?5KViews0likes2CommentsNot sure How to Use Two cable and Cat 5 Plug Set UP
Living room wall has a recepticle with two cable and a Cat 5 plug set up. Using one cable plug for DVR Box and TV, works great. Can I use second cable plug for modem and send Ethernet cable back into Cat 5 plug. Then in other room with only Cat 5 plug, tie in wireless router with ethernet cable into Cat 5 plug and port one into computer. Is this how to use the Cat 5 outlet? Two cable hook ups eliminates splitter?3.5KViews0likes1Comment
