Critical T3 Errors - Multiple
Need some assistance. I've had multiple issues with disconnects while gaming and the history of errors listed below is alarming. Need some advice. Connections are tight and secure. No splitters in line. Cox installed coaxial cables. I've done the trouble shooting within the apartment. Sat Nov 23 01:48:43 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MA... Mon Nov 25 21:38:42 2019 Notice (6) TLV-11 - unrecognized OID;CM-MAC= ;CMTS-MAC=... Tue Nov 26 15:12:18 2019 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/... Tue Nov 26 15:12:18 2019 Warning (5) MDD message timeout;CM-MAC= ;CMTS-MAC=70:6e:... Tue Nov 26 15:12:21 2019 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/... Tue Nov 26 15:12:22 2019 Warning (5) MDD message timeout;CM-MAC= ;CMTS-MAC=70:6e:... Tue Nov 26 15:12:56 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Tue Nov 26 15:13:00 2019 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=00... Tue Nov 26 15:15:48 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Tue Nov 26 15:15:48 2019 Critical (3) Unicast Maintenance Ranging attempted - No response - Retrie... Tue Nov 26 15:15:48 2019 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream... Tue Nov 26 15:18:47 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Tue Nov 26 15:18:47 2019 Critical (3) Unicast Maintenance Ranging attempted - No response - Retrie... Tue Nov 26 15:18:47 2019 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream... Tue Nov 26 15:19:07 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Tue Nov 26 15:19:07 2019 Critical (3) Unicast Maintenance Ranging attempted - No response - Retrie... Tue Nov 26 15:19:07 2019 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream... Tue Nov 26 15:28:27 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Tue Nov 26 15:29:09 2019 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=00:40:36:4... Thu Nov 28 07:37:54 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Fri Nov 29 03:43:24 2019 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-... Sat Nov 30 05:43:25 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -... Sat Nov 30 05:43:27 2019 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MA... Sat Nov 30 05:44:32 2019 Critical (3) Received Response to Broadcast Maintenance Request, But no U... Sat Nov 30 10:34:19 2019 Critical (3) Started Unicast Maintenance Ranging - No Response received -...725Views0likes1CommentLost signal issues
Hey there, hoping to get some assistance here. I have been having issues with the modem itself dropping out. Tonight, I wanted to try something out, so I hooked up the modem outside to eliminate my house wiring which is older and questionable at best. I don't know enough about this stuff to look at the below numbers to know if this is any good or bad. This is coming from my Motorola Surfboard 6120, if i recall the model correctly. \Solved4.3KViews0likes6Comments
