- DominoValued Contributor III
There is a photo of an installation over on AVS.
- ChrisLFormer Moderator@JohnnyG
Do you currently have any other auxiliary devices connected to your TV now such as a DVD/Blu-ray player or gaming system? If so the process of adding a min-box should be physically similar.
- JohnnyGNew ContributorChris, there is nothing on the wall but that TV. I was just trying to avoid a shelf on that wall just for the mini box
ChrisL said:
@JohnnyG
- rebeccaanthonyNew Contributor III
Is there room behind the tv? if so mount the box back there then go to amazon buy an ir repeater that runs off usb power plug into "service" usb on tv and you can keep everything invisible so to speak http://www.amazon.com/Infrared-Extender-Receiver-Emitter-Repeater/dp/B00AMTRR5K/ref=sr_1_2?ie=UTF8&qid=1428694429&sr=8-2&keywords=ir+repeater
Like this?
http://forums.cox.com/forum_home/tv_forum/f/4/p/35441/editpost.aspx?ReturnUrl=
