Rik's avatar
Rik
11 years ago
auto-shut off of TV cable
I am very unhappy with a new (in the last year) practice of Cox Communications services. After several hours of viewing (or recording) they shut down the cable service! I have missed the ends of numerous sports events and movies because of this. How can I shut this off and get my cable to stay on?
  • Domino's avatar
    Domino
    Valued Contributor III
    Is your entire cable shutting down, or is your cable box just shutting off? What box do you have? What program guide (Rovi Passport or Contour)?? If Contour, it could be as simple as turning OFF the automatic shut-down feature. Go to:
    SETTINGS -> RECEIVERS -> POWER MANAGER -> RECEIVER POWER
    and set to POWER OFF MANUALLY.
  • Rik's avatar
    Rik
    It is shutting down just as if I pushed the power button on the remote. The box I have is a Cisco and I'm pretty sure it's not a Contour.
    Your solution worked....or at least time will tell. (fingers crossed).
  • Domino's avatar
    Domino
    OK, so the cable isn't shutting off, just the box. All Cisco DVRs have a model number. 8642HDC? 8742HDC? 9865HDC? If your guide has the menu string I suggested, then it is indeed Contour. What does it say in the lower left corner when the grid guide is showing?
